Ansys Fluent melting/solidification model equations
    • Jada
      I have a few questions regarding the fundamental equations used in the melting/solidification model for phase change materials in ANSYS Fluent.
      With reference to the energy and momentum sink equations (17.4-5) and (17.5-1) in release 12.0 of the Ansys Fluent theory guide, how is the fluid velocity term calculated, and where is the value of the mushy zone derived from?  I have attached the equations below for reference, and the theory guide can be accesed here. Thanks.
      Energy Equation:
      Momentum sink equation:
      Kind regards,
      Jada
    • Amine Ben Hadj Ali
      The velocity is fixed using that source term into the momentum equation. I recommend using supported Online Help. Release 12 is not supported anymore.
    • Jada
      Thank you for getting back to me.
      How are the velocity terms in the source term and energy equation coupled? Also, where can I locate the theory guide/supported help for the most latest release?
      Kind regards,
      Jada
      Check the Solidification and Melting Model in the Theory Guide: you won't miss it.
      To get the (online) help: wherevever you are in Ansys Fluent just Hit F1 then navigate to main Help landing page.
      • Jada
        Ok, I will try that. Thank you for your help.
  • The topic ‘Ansys Fluent melting/solidification model equations’ is closed to new replies.
