December 22, 2022 at 1:57 pm
John Miller
SubscriberHello,
I*m trying to model radiation in an AM process in Workbench thermal transient module.
The scripting of the element birth for AM modelling is easy and doesn't make any problems, but the use of surf152 elements for adding radition effect puzzles me a bit.
I'm generating a component of nodes wich are only on the surface (only exterior nodes) of the generated material (red part in the image)
I would like to use this component as basis for the creation of SURF152 Elements:
cm,external,node
For the creation of surface elements I need to go the /prep7 create the elements and after this go back to /solu
*do,...
other code
solve
/prep7
/GOPR*get,nmax,etyp,,num,max
eakt=nmax+1
*get,mmax,node,,num,max
nakt=mmax+1et,eakt,surf152 !Surf152 Element
keyopt,eakt,5,1 !Extra node
keyopt,eakt,9,1 !Radiation with form factor reale konstant
keyopt,eakt,11,1 !Node DOF-TTOP
r,eakt,1,5.8e-8 !Stefan Boltzman konstant
mp,emis,?,0.5 !Emissivity coefficient
mat,eakt !Material
type,eakt !Type
real,eaktesel,s,type,,?
esurf,nakt
d,nakt,temp,tamb
alls
toffst,273
/solu
nropt,full....
...further processing
*enddo
I'm struggeling to create the surf152 on top of the exterior nodes, maybe some has a clue to break down this obstacle
Greetings
John M.
December 26, 2022 at 4:19 pm
dlooman
Ansys EmployeeYou need to select the nodes on the surface prior to the esurf, not elements. A possible way would be to use a named selection for the faces you want to apply the surf152 elements to. Then cmsel,s,named_selection would select those nodes prior to the esurf command. The radiation capability in Mechanical would seem to be a better way to model radiation though.
January 1, 2023 at 4:10 pm
John Miller
SubscriberHappy New Year,
@Dave Looman, thanks for your answer.
I define in the load loop a component, which includes the currently active external nodes of the extruded material:
cm,external,node
I’m struggling still with the esurf command:
ESURF,
XNODE,Tlab,Shape
Generates elements overlaid on the free faces of selected nodes.The XNODE definition is not really clear to me.
With your suggestion, I would script the radiation as follows:
*do,…
Load
/prep7
/GOPR
eakt=nmax+1
nakt=mmax+1
et,eakt,surf152 !Surf152 Elements
keyopt,eakt,5,1 !Extra nodes
keyopt,eakt,9,1 !Radiation with form factor real constant
keyopt,eakt,11,1 !Nodes DOF-TTOP
r,eakt,1,5.8e-8 !Stefan Boltzman constant
mp,emis,eakt,0.5 !Emissivity coefficient
mat,eakt !Material assignment
type,eakt !Type assignment
real,eakt
cmsel,s,external
esurf,nakt
d,nakt,temp,tamb
alls
toffst,273
/solu
nropt,full
Load or something else
*enddo
Is the radiation with this code applied or is something else necessary in the load stage(/solu) after leaving the /prep7 ?
Greetings
John M.
January 1, 2023 at 4:08 pm
John Miller
Subscriber -
January 4, 2023 at 2:54 pm
dlooman
Ansys EmployeeHi John, You have have to create the extra node. Its physical location doesn't matter so it can be at the origin: n,nakt,0,0,0. I think if you do that this script will work.
Dave
January 5, 2023 at 8:27 am
John Miller
SubscriberHi Dave,
thanks for your support. I added an extra node and some code to delete the surf152 elements of the last step.
I also changed the node selection a little bit to:
cmsel,s,external,nodes ! Select nodes for esurf
esel,all ! Select elements for esurf (including the “external” nodes)
esurf ! Creation of surface elementsit differs from the former version:
cmsel,s,external
esurf,naktI’m not sure if my current version of nodal and element selection previous to esurf is doing the right thing.
The whole script would look like this:
/prep7 ! Pre processor
/GOPR*get,nmax,etyp,,num,max ! nmax=name of resulting parameter, Entity=etyp aka Element typ,ENTNUM=blank, Item1=num,IT1NUM=max aka maximum number, Item2=blank,IT2NUM=blank
eakt=nmax+1 ! maximum element typ number +1
*get,mmax,node,,num,max ! mmax=name of resulting parameter, Entity=node,ENTNUM=blank, Item1=num,IT1NUM=max aka maximum number, Item2=blank,IT2NUM=blank
nakt=mmax+1 ! maximum node number +1n,nakt,0,0,0 ! Creation of extra node
et,eakt,surf152 ! Surf152 Elements
keyopt,eakt,5,1 ! Extra nodes
keyopt,eakt,9,1 ! Radiation with form factor real constant
keyopt,eakt,11,1 ! Nodes DOF-TTOP
r,eakt,1,5.8e-8 ! Stefan Boltzman constant
mp,emis,eakt,epsilon ! Emissivity coefficient
mat,eakt ! Material assignment
type,eakt ! Type assignment
real,eakt ! Real constantesel,s,ename,,surf152 ! Element selection of surf152 elements
cm,ELsurf152,elements ! Create a component which includes surf152 elements
edele,ELsurf152 ! Deletion of former surf152 elementscmsel,s,external,nodes ! Select nodes for esurf
esurf ! Creation of surface elementsd,nakt,temp,tamb ! Temperature of the the extra/space node, Temperature=ambient Temperature
alls
toffst,273 ! Specifies the temperature offset from absolute zero to zero, 273 for the Celsius system
/solu ! Re-entering the solutionGreetings
John M.
January 5, 2023 at 2:40 pm
dlooman
Ansys Employeeesurf,nakt was correct. You shouldn't have changed that. You want esurf to create the surf152 with nakt as their extra node to radiate to.
January 6, 2023 at 8:48 am
John Miller
SubscriberHi Dave,
thank you very much for your hint regarding esurf command.
With that I would state the radiation like this:
*do,…
Element ealive
Load application
/prep7
edele,ELsurf152 ! Deletion of former surf152 elementsDoes it make sense to erase the surf152 elements? I’m not sure about it.
In every step ot the do loop, elements were activated and thermal load is applied.
Therefore, the external Nodes for radiation application is constantly changing. I would guess that deletion of former surf152 elements is necessary.
Is the position right or should be "outside" in the /solu part of the loop?
esurf,nakt ! Creation of surface elementsd,nakt,temp,tamb ! Temperature of the the extra/space node, Temperature=ambient Temperature
alls
toffst,273 ! Specifies the temperature offset from absolute zero to zero, 273 for the Celsius system/solu
nropt,full
*enddo
How can I prove that the script is working?
Is there a way to visualise the radiation with the aid of /post ?
Greetings
John M.
January 6, 2023 at 3:07 pm
dlooman
Ansys EmployeeA way in APDL POST1 would be to retrieve the heat flow to the space node. Check the APDL element documentation for other ways to postprocess surf152 results.
/post1
set,last
nsel,s,,,natk
prrsol
- The topic ‘Use of esurf for creating SURF152 elements’ is closed to new replies.
4878
1587
1386
1242
