TAGGED: ansys-mechanical, mechanical, random-vibration
December 20, 2022 at 4:03 am
dergance
SubscriberHello all,Â
I'm trying to run a random vibration analysis in Ansys Mechanical 2022 R1 of a part that is constrained to ground through Bushing Joints which are used to capture bolt stiffness. The Random Vibration boundary condition requires a single constraint input and a grounded joint is not a constraint. Is there a way to get around this problem?Â
In Nastran I would create my Bushing element between my part and a node with a fixed constraint, but Ansys doesn't seem to allow me to create a Bushing Joint between my part and something that I can apply a fixed boundary condition on. My workaround has been to bring in geometry that I can set as Rigid and then apply a fixed constraint to that and create Bushing body-to-body joints between the part I want to analyze and this rigid foundation part.Â
Thanks!
December 20, 2022 at 1:19 pm
peteroznewman
SubscriberThat is a good way to model the constraint to ground and include a Bushing element.
- The topic ‘Grounded joints as boundary condition for Random Vibe analysis’ is closed to new replies.
5859
1305
