Photonics
Photonics
About Exporting “GDSII File” Using FDTD
    • tsinghuaby
      Is there any size limit for using FDTD to export "GDSII file"? My structure took a long time to export without success. The exported file cannot be opened with relevant software, as shown below:
      Look forward to the teacher's reply!
    • Guilin Sun
      With very little information, it is hard to say what is the cause. Please refer the example: https://optics.ansys.com/hc/en-us/articles/1500006203341-GDSII-Export-Automation
      I would suggest to test the case with fewer geometry and see if it works.  GDSII supports limited number of points, depending on the version. Here are a few posts that might be helpful:
      Lumerical FDTD gds export vertices limit
      如何导出结构组?
  • The topic ‘About Exporting “GDSII File” Using FDTD’ is closed to new replies.
