November 28, 2022 at 4:24 pm
ehsan.sadeghi
SubscriberI am using Fluent 2022R2 to run a simple UDF. I have installed Visual Studio version 2022, however I get the following error message:
1 error generated.
scons: *** [udf_names.obj] Error 1
'nmake' is not recognized as an internal or external command,
operable program or batch file.
I have tried using builtin compiler of fluent, using visual studio versions 2017 and 2019, but the problem persists.Â
November 29, 2022 at 5:56 am
Nikhil N
SubscriberHello,
Though I am not an expert on this, I have a couple of suggestions.
1: Can you try running Fluent from the VS command prompt?
2: If not, in the Environment Variables settings, make sure that the directory containing 'nmake.exe' is in the 'Path' variable.ÂÂThanks,Nikhil -
November 29, 2022 at 6:38 am
ehsan.sadeghi
SubscriberHello, I have already done that. Seems that there is a version conflict of visualstudio. though I have uninstalled all versions of visual studio in oeder to use Fluent´s builtin compiler the problem persists. Therefore we proceeded with changing the windows!Â
November 29, 2022 at 7:16 am
Nikhil N
SubscriberCan you check if the the fluent root path is correct (in the launcher window)? and also check if nmake is available in the installation directory.Â
December 7, 2022 at 8:58 am
ehsan.sadeghi
SubscriberI mark it as answered! the problem was not solved. Finally I had to have a fresh installation of windows to be able to use builtin compiler of Fluent.Â
December 9, 2022 at 9:59 am
Nikhil N
SubscriberIf the 'nmake' error still persists, make sure that the VS is installed with sufficient permissions on Windows.
- The topic ‘UDF compile error’ is closed to new replies.
5824
1305
