November 23, 2022 at 4:25 am
Shyam Prasad V Atri
SubscriberWhen I run dpm particles with axis BC the particles cross the axis BC and go to domain where geometry is not existent on fluent. How can this be fixed?Â
November 23, 2022 at 9:55 am
Nikhil N
SubscriberHello,
This should not happen because for axis boundaries, the solver assumes 'reflect type' boundary condition by default. You may want to check this section of the user's guide: 20.4. Setting Boundary Conditions for the Discrete Phase (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Check if correct DPM boundary conditions have been assigned to the wall boundaries.Â
Thank you
Nikhil
November 23, 2022 at 5:42 pm
Shyam Prasad V Atri
Subscriberi agree it should not happen. In case such a thing occurs how would i fix it?
i have checked all my boundary condition it still occors. few particles just go out of the axis. Can you please tell me how to fix it.
November 24, 2022 at 8:05 am
Nikhil N
SubscriberAre you running a 2D axis-symmetric case?Â
November 24, 2022 at 8:16 am
Nikhil N
Subscriber"particles cross the axis BC and go to domain where geometry is not existent on fluent."
Can you also share some screenshots?
December 1, 2022 at 12:15 am
December 1, 2022 at 12:16 am
Shyam Prasad V Atri
SubscriberYou see the horizontal thing on the right is the axis why is the particle going out of the axis? what could possibly cause this
- The topic ‘Fluent axis BC’ is closed to new replies.
3862
1414
1221
1118
1015
