How to command Fluent Set up – Initialization – Patch in TUI Journal
    • Lee myungjun
      In Fluent Set up component, how I command patch in jounal text file
      I inserted like below image.
      What's wrong command here?
      please help me, thanks
      As a tip, use /file/read-case ie always use the full command with the / character to ensure Fluent uses the full command.
      Looking at the command, in the Fluent TUI type in solve and look at the options, pick Patch and hit enter twice again to see the next level of menu. Chances are you’ve missed a phase or zone label in the command.
      One final comment. I’d suggest saving case & data when running, and maybe decrease the save frequency unless you’re doing to this to post-process data. Every time time is a little excessive!
    • Lee myungjun
      Really thanks for your reply.
      Could I know full command of the above example?
    • Lee myungjun
      Baerly I resolve this problem using command below:)
  • The topic ‘How to command Fluent Set up – Initialization – Patch in TUI Journal’ is closed to new replies.
