November 7, 2022 at 5:38 pm
Laura Pałys
SubscriberHi, Does anyone know how I could get the results of scalar shear stresses (in a numerical mesh generated automatically in ICFD). I need these values as a criterion for evaluating a medical device. I found a relationship between stresses and velocity gradient. I wonder how to introduce these equations into LS-DYNA.
November 11, 2022 at 1:34 am
Reno Genest
Ansys EmployeeHello Laura,
Have a look at *ICFD_DATABASE_DRAG in the user manual vol III:
You can output the drag forces and moments on surfaces. It will split the drap forces into pressures forces (normal to the surface) and viscous forces (tangent to the surface which is what you want). With these forces, you should be able to calculate the shear stresses. Here is what you will find in the manual:
I don't know if it is possible to output shear stresses directly.
Reno.
November 11, 2022 at 6:52 pm
November 23, 2022 at 2:59 pm
Laura Pałys
SubscriberDear Reno,
thank you for your response.Unfortunately, I am unable to manage with my problem. I used the DATABASE_DRAG_VOL (I also put 1 for ELOUT card), but but this is still the value for the surface when I want to compute the same value for each element.
Do you know how can I get the values of individual components (pressure, velocity) in text form? For this, I would also need information about the size of the surface that the element consists of. Additionally, the simulation is transient and the remeshing follows.
November 23, 2022 at 4:42 pm
November 28, 2022 at 6:21 pm
November 30, 2022 at 11:16 am
January 12, 2023 at 7:37 pm
Laura Pałys
SubscriberThe best solution is to calculate the shear stresses in Ensight or Paraview. The topic can be closed.
- The topic ‘ICFD- FSI stress output’ is closed to new replies.
6450
