November 6, 2022 at 8:03 am
kevin1986
SubscriberHi guys,
I installed ansys 2022 r1, 2019 r1 and 2022 r1. I use these different ansys fluent to run my test case. I found fluent 2022 r1 is much slower than others. I am quite confused since the hardware (cpu and memory) is the same. After further debugging, I found fluent 2022 r1's bandwidth (slowest is around 100 mb/s, fasters is 2000 mb/s, but the value changes every time) is much slower than others (slowest is around 1500 mb/s). All of them I used intelmpi, with 64 cores.Â
What can I do?
Thanks.Â
November 6, 2022 at 8:41 am
kevin1986
Subscriber-
November 22, 2022 at 4:38 pm
MangeshANSYS
Ansys EmployeeHello,
we could compare two different Fluent versions on same machine or same Fluent version on twi different machines, but not 2 different versions on 2 different computers at the same time..
Are the screenshots from two differrent machines or two different user profiles on same machine? Is there variation seen on the same machine with 2 different versions of Fluent and MPI or are we comparing this data from 2 different machines ?
If only one machine is used for solcing then please also try microsoft MPI from lauuncher parallel settings
If still seeing issues then can you please provide processor make and model, memory quantity and configuration (4 DIMMs of 8 GB etc)
December 29, 2022 at 6:21 am
kevin1986
SubscriberHello Mangesh,
Thanks for your reply. We did the comparison of different fluent version on SAME machines. We do have several workstations, but we did the comparison of different fluent version on SAME machine. We found the bandwidth is different on SAME machine. We suspect it comes from intelMPI. Although microsoft MPI of Fluent 2022 is also slow.Â
The processors are amd epyc 7642/7543/7302. 16 DIMM of 16G. We have several workstations with different CPUs. But it should be noted we did the test on same machine.Â
It should be noted that linux ansys fluent 2022 is much faster. The calcultion speed of linux fluent 2022 is the same with windows fluent 2020.Â
November 7, 2022 at 1:28 pm
kevin1986
SubscriberI think its because the new version uses intelmpi2019, but the old version uses intelmpi 2018. Â
Is it possible to let ansys fluent 2022 to use intelmpi 2018?
November 9, 2022 at 12:05 am
kevin1986
SubscriberIn the parallel switch, after typing "intel2018" I can use intelmpi2018. I did several tests, intelmpi2018 is better than intelmpi2019 (intel). But its still slow. I cannot figure out why.
November 15, 2022 at 6:32 am
kevin1986
SubscriberThe slow parallel bandwidth makes the calculation in Fluent 2022 much slower than that of Fluent 2020...
April 25, 2023 at 12:31 pm
Ghobad Bagheri
SubscriberHi Kevin,Â
Have you found any solution for the bandwidth problem? I have the same issue with Ansys 2023 R1. The bandwidth is so low that a system with AMD 64 cores performs the same as my other system with 16 cores (Ansys 2021 R2).Â
April 26, 2023 at 4:28 am
kevin1986
SubscriberNope. This problem looks like a bug, either comes from intelmpi windows version, or fluent 21/22/23 windows version. I dont know.
The latest please check here: /forum/forums/topic/new-version-fluent-is-slower-than-2020r2/
May 2, 2023 at 12:37 pm
kevin1986
SubscriberMeanwhile, I suggest you switch to Fluent 2020r2, you will see its much faster. Please let me know if you have any updates.Â
May 2, 2023 at 1:07 pm
Ghobad Bagheri
SubscriberI tried Fluent 2020r2, and the Bandwidth was ok. So I am running my simulation on F2020. I am going to report the bug.Â
May 2, 2023 at 1:16 pm
kevin1986
SubscriberThank you Ghobad. I dont know where to report the bug except this forum. Maybe you have another ways to do it. But please let me know as well when ANSYS fixes it. Much appreciated!Â
May 2, 2023 at 2:12 pm
Ghobad Bagheri
SubscriberI have a contact point where I can report the bug. I will keep you posted.Â
May 10, 2023 at 10:02 am
kevin1986
SubscriberGhobad, did ansys team reply your answer? Thanks.Â
May 10, 2023 at 10:14 am
Ghobad Bagheri
They are still investigating the problem. I shared the info needed to convince them that there is a bug.Â
By the way, I found a workaround. You can run Fluent from the terminal (any version) by enforcing INTEL MPI 2018, which is the version with better performance. You can use the following syntax.Â
'fluent 3ddp -t24 -mpi=intel2018'
Description:
3ddp= 3D with double precisionÂ
t24= number of coresÂ
May 23, 2023 at 11:47 am
kevin1986
SubscriberHello Ghobad, I am wondering if they give you any solutions regarding this problem. Thanks.Â
D
May 23, 2023 at 2:36 pm
Ghobad Bagheri
SubscriberHi Kevin,
I shared the benchmark with them, and it is evident that the performance was not the same. I haven't heard back from them yet.
May 24, 2023 at 11:42 am
kevin1986
SubscriberThank you for your update, Ghobad. Lets see.
D
May 10, 2023 at 2:51 pm
kevin1986
SubscriberThanks Ghobad. I also tried to use intel2018 in GUI (type intel2018 manully). Please see the latest results.Â
- default intel's bandwidth is very slow, even 4 cores are used. Only 1000-1400.
- when 4 core is used. Intel2018's bandwidth is around 9000. Very good. much better than default intel.
 - when 64 cores are used. Intel2018's minimum bandwidth drops to 900, which slow down the calculation seriously.
4. msmpi has similar issue. Also slow
At last, I would say Fluent 2020r2 does not have this issue at all. I hope this information can help them debug further about this issue :-)
June 2, 2023 at 3:18 pm
Otari Kemularia
Subscriber-
June 3, 2023 at 12:25 pm
kevin1986
SubscriberWin 10 Pro is not the problem. I tested win10Pro and win2019 server. All has this issue.Â
This problem is not shown in Cent OS system.
June 3, 2023 at 12:43 pm
Otari Kemularia
SubscriberIs it pain in the ass to setup a cluster with Cent OS and send the simulations from the main workstation?
June 5, 2023 at 7:13 am
kevin1986
SubscriberIf you want to use multiple nodes, its a bit tedious to install slurm etc.
If you just want to install ansys on CENTOS. Its very easy.
June 5, 2023 at 7:28 am
Otari Kemularia
SubscriberCan I open 2022 R2 files, created in Win 10 with ansys on Centos? I have almost zero experience with linux
June 5, 2023 at 6:04 pm
kevin1986
SubscriberYes you can.Â
June 5, 2023 at 12:33 pm
Ghobad Bagheri
SubscriberThe default setting for MPI doesn't work the best with AMD Threadripper. So we need some fine-tuning as follows:
In the launcher, set MPI to MSMPIÂ
and use the following syntaxes in the environmental tab.Â
FLUENT_AFFINITY=0
MPIEXEC_AFFINITY=3:P
Using this setting, Fluent 2023R1 and Fluent 2020R2 perform similarly with comparable computational time. Please update me if you achieve the same improvement.
June 5, 2023 at 6:05 pm
kevin1986
SubscriberThank you very much Ghobad. I will try and keep you updated asap.
June 5, 2023 at 6:30 pm
Otari Kemularia
SubscriberIt definately worked for 5800x, now I'm gonna test it for 2X7532.
Thank you Kevin for opening this thread.
Thank you Gobad for helping us out.
June 5, 2023 at 6:32 pm
kevin1986
SubscriberI justed tried, it works like a charm!
Do does it mean we cannot intelmpi for newer versions?
June 5, 2023 at 9:20 pm
Otari Kemularia
Subscriber -
June 6, 2023 at 4:55 am
kevin1986
Subscriberyeah, I also notice 2020 is faster. But now is much much better than before.
- The topic ‘fluent 2022 r1 slow bandwitdth’ is closed to new replies.
6465
