Ansys Products
Ansys Products
Ansys Fluent watertight workflow generating meshing “Error: Poly meshing no”
    • mehdi Abbas
      I am getting this error while I try to mesh a concentric cylinderical object with thin walls. The thickness of the outter wall is 0.14mm. XCan anyone suggest as to what the solution could be for this
      Error: Poly meshing not completed.
      Error Object: #f
      Error Object: #f
    • Nikhil N
      Hello, what is the minimum size of the surface mesh?
      Can you also share the screen grabs of the CAD, surface mesh, and the error?
      Are you also adding BL?
  • The topic ‘Ansys Fluent watertight workflow generating meshing “Error: Poly meshing no”’ is closed to new replies.
