TAGGED: harmonic-analysis, piezoelectric, strain-energy
October 19, 2022 at 1:00 pm
Md_Salem
SubscriberHi everyone,
I am doing a harmonic analysis for piezo actuator attached to the surface of cantilever plate.
I need to display (strain energy) of the system / piezo actuator , after solution is done and from the solution context tab, I clicked strain and searched for Energy in the drop-down menu. I found it but unlighted as shown in the picture, so I cannot display the strain energy
October 19, 2022 at 1:15 pm
Erik Kostson
Ansys EmployeeÂ
Can you set under the Analysis settings and output controls all to Yes. I think even with that it does not show.
The reason might be as per the help manual under strain energy section, that it includes plastic strain which we can not have in a harmonic analysis (only linear material).
One can add perhaps some user defined results – see worksheet summary under the solution in the mechanical tree and there should be some energy results (e.g., ENERGYPOTENTIAL).
Erik
October 20, 2022 at 9:05 am
October 20, 2022 at 9:21 am
Erik Kostson
Ansys EmployeeThe reason might be as per the Ansys help manual and under the strain energy section, that it (strain energy) includes plastic strain which we can not have in a harmonic analysis since it is a linear analysis (so only linear material, hence no plasticity can be included).
Erik
- The topic ‘strain energy of coupled field system’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
4167
1487
1363
1194
