September 30, 2022 at 8:13 pm
eleblanc-royer
SubscriberWhen I first installed SiWave I accidentally entered the incorrect license server informatino so SiWave would not even start correctly. I fixed this by running "C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ClientSettings\ClientSettings.exe" and changing the license server host name and port to be correct. This allows SiWave to startup and run, however whenever I try to perform any simulations I get errors about accessing the simulation license server. When I look at the error log it appears that "ansyscl" is using the old, incorrect, license information. Is there somewhere else that I need to change the license server information? Thank you
October 3, 2022 at 1:24 pm
George Karnos
Ansys EmployeeÂ
Check the following file for the correct license server name:
C:\Program Files\AnsysEM\Shared Files\licensing\ansyslmd.iniIf it is not, change it to the correct name and save file.
If it is correct, please check the %TEMP%\.ansys directory for the siwave licdebug file.
iF there is an error contained in that file, please post it.Â
October 3, 2022 at 2:53 pm
eleblanc-royer
SubscriberI have pasted a snippet of what the erorr looks like from within SiWave at the bottom of this reply. I have blocked out my computer and host name. Additionally, I have pasted the log it is pointing to below. I have redacted my user name and host computer name. The one thing that seems out of place to me is where it states "2022/10/03 10:37:27Â Â INFOÂ Â Â Â Â Â Â Â ANSYSLI_PRODORD_FILE=COULD NOT BE FOUND!". Is that potentially my issue?Â
*Start of Log file*-------------------------------------------- NORMAL STARTUP 2022/10/03 10:37:27 ---------------------------------------------ÂAnsys Licensing Interconnect version 2022.2.0 (20220502) for winx64. Updated at Ansys Release 2022 R2. Started on 2022/10/03 10:37:27 by@ :winx64 with pid 17560. (C) 2022 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited.Built Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6Built Using OpenSSL 1.1.1n 15 Mar 2022Â-----------------------------------------------------------------------------------------------------------------------------ÂPlease note that entries in this debug log have the following format:ÂTIMESTAMP       ACTION       FEATURE          REVISION (BUILD DATE)       A/B/C/D         W/X/Y/Z  PID:MPID:APP:USER@HOST:PLATFORM:DISPLAY                  SOCKET:IP     ÂÂLicenses statistics:--------------------A is the number of licenses requested by this ACTION.B is the number of licenses used by this USER.C is the number of licenses used by all users.D is the number of licenses available in the local license pool.ÂLicense server performance statistics:--------------------------------------W is the number of currently connected client applications.X is the maximum number of connected client applications.Y is the unique serial number of this client application.Z is the number of all client applications served by this Licensing Interconnect server.Â-----------------------------------------------------------------------------------------------------------------------------2022/10/03 10:37:27  INFO        ANSYSLI_CMD=C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .15192.32727.log 2022/10/03 10:37:27  INFO        ANSYSLI_INITIALIZATION_FILE='C:\Program Files\AnsysEM\Shared Files\Licensing\ansyslmd.ini'2022/10/03 10:37:27  INFO        ANSYSLI_PRODORD_FILE=COULD NOT BE FOUND!2022/10/03 10:37:27  INFO        ANSYSLI_TIMEOUT_FLEXLM=152022/10/03 10:37:27  INFO        Configuring ACL Core2022/10/03 10:37:27  INFO        ACL Core Initialized2022/10/03 10:37:27  INFO        ANSYSCL_PORT=51980Â2022/10/03 10:37:27  INFO        Listen Socket Created2022/10/03 10:37:27  INFO        ANSYSLI_CLIENT_IDLE_TIMEOUT=02022/10/03 10:37:27  INFO        ANSYSCL_FNP_PATH=1055@linflex42022/10/03 10:37:27  INFO        Ready to accept connections.2022/10/03 10:37:27  INFO        ANSYSLI_IP_OVERRIDE option is off.2022/10/03 10:37:28  CLIENT_ACCEPT                                              1/1/1/1                                       7408:127.0.0.1   Â2022/10/03 10:37:28  CLIENT_CONNECT                                              1/1/1/1  15192:15192:SIWAVE.EXE:@ :winx64       7408:127.0.0.1    2022/10/03 10:37:28  CHECKOUT      electronics3d_gui        22.2 (2022.0502)      1/1/1/10         1/1/1/1  15192:15192:SIWAVE.EXE:@ :winx64       7408:127.0.0.1    2022/10/03 10:37:28  CHECKOUT      FEAT_ELECTRONICS3D_GUI     22.2 (2022.0502)       1/1/1/1         1/1/1/1  15192:15192:SIWAVE.EXE:@ :winx64       7408:127.0.0.1    End of Log file
SiWave Error
October 3, 2022 at 5:31 pm
George Karnos
Ansys Employeecan you paste the contents of the licdebug.
.SIWAVE.EXE.221.out file located under %TEMP%\.ansys -
October 3, 2022 at 5:43 pm
eleblanc-royer
SubscriberHello,Â
Yes I have two files:Â
First one "licdebug.XXXX.SIWAVE.EXE.222.out"
2022/09/27 12:44:11 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/27 12:44:11 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 9376.25533 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .9376.25533.log
2022/09/27 12:44:12 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/27 12:44:13 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 9376:SIWAVE.EXE:@ :winx64 Â Â 7388:10.14.0.93 Â Â Â
2022/09/27 12:44:13 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 61485@127.0.0.1.
2022/09/27 12:44:13   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  9376:SIWAVE.EXE:@ :winx64   7388:10.14.0.93   Â
2022/09/27 12:44:13 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 9376:SIWAVE.EXE:@ :winx64 Â Â 7388:10.14.0.93 Â Â Â
2022/09/27 15:13:16 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 9376:SIWAVE.EXE:@ :winx64 Â Â 7388:10.14.0.93 Â Â Â
2022/09/28 11:50:56 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/28 11:50:56 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 18040.33621 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .18040.33621.log
2022/09/28 11:50:56 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/28 11:50:57 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 18040:SIWAVE.EXE:@ :winx64 Â 7392:10.14.10.38 Â Â
2022/09/28 11:50:57 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 57352@127.0.0.1.
2022/09/28 11:50:57   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  18040:SIWAVE.EXE:@ :winx64  7392:10.14.10.38  Â
2022/09/28 11:50:57 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 18040:SIWAVE.EXE:@ :winx64 Â 7392:10.14.10.38 Â Â
2022/09/28 16:06:14 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 18040:SIWAVE.EXE:@ :winx64 Â 7392:10.14.10.38 Â Â
2022/09/29 10:43:40 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/29 10:43:40 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 16124.53166 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .16124.53166.log
2022/09/29 10:43:40 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/29 10:43:41 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 16124:SIWAVE.EXE:@ :winx64 Â 7500:10.14.4.130 Â Â
2022/09/29 10:43:41 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 49763@127.0.0.1.
2022/09/29 10:43:42   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  16124:SIWAVE.EXE:@ :winx64  7500:10.14.4.130  Â
2022/09/29 10:43:42 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 16124:SIWAVE.EXE:@ :winx64 Â 7500:10.14.4.130 Â Â
2022/09/29 12:35:23 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 16124:SIWAVE.EXE:@ :winx64 Â 7500:10.14.4.130 Â Â
2022/09/29 14:43:26 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/29 14:43:26 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 504.51432 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .504.51432.log
2022/09/29 14:43:26 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/29 14:43:26 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 4828.51432 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .4828.51432.log
2022/09/29 14:43:27 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 504:SIWAVE.EXE:@ :winx64 Â Â 7428:10.14.4.130 Â Â
2022/09/29 14:43:27 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 52549@127.0.0.1.
2022/09/29 14:43:27   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  504:SIWAVE.EXE:@ :winx64   7428:10.14.4.130  Â
2022/09/29 14:43:27 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 504:SIWAVE.EXE:@ :winx64 Â Â 7428:10.14.4.130 Â Â
2022/09/29 14:43:27 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:43:27 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 52554@127.0.0.1.
2022/09/29 14:43:28   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  4828:SIWAVE.EXE:@ :winx64   7404:10.14.4.130  Â
2022/09/29 14:43:28 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:45:30 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 504:SIWAVE.EXE:@ :winx64 Â Â 7428:10.14.4.130 Â Â
2022/09/29 14:52:07   CHECKOUT       elec_solve_siwave        22.2 (2022.0502)       1/1/1/4         1/1/1/1  4828:SIWAVE.EXE:@ :winx64   7404:10.14.4.130  Â
2022/09/29 14:52:07 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELEC_SOLVE_SIWAVE Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:08 Â Â CHECKOUT Â Â Â Â Â Â elec_solve_level3 Â Â Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/4 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:08 Â Â CHECKOUT Â Â Â Â Â Â elec_solve_level2 Â Â Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/10 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:08 Â Â CHECKOUT Â Â Â Â Â Â elec_solve_level1 Â Â Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/10 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:08 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELEC_SOLVE_LEVEL1 Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:08 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELEC_SOLVE_LEVEL2 Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:08 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELEC_SOLVE_LEVEL3 Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:19 Â Â CHECKIN Â Â Â Â Â Â FEAT_ELEC_SOLVE_SIWAVE Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/0/0/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:19   CHECKIN       elec_solve_siwave        22.2 (2022.0502)       1/0/0/4         1/1/1/1  4828:SIWAVE.EXE:@ :winx64   7404:10.14.4.130  Â
2022/09/29 14:52:19 Â Â CHECKIN Â Â Â Â Â Â FEAT_ELEC_SOLVE_LEVEL1 Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/0/0/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:19 Â Â CHECKIN Â Â Â Â Â Â elec_solve_level1 Â Â Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/0/0/10 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:19 Â Â CHECKIN Â Â Â Â Â Â FEAT_ELEC_SOLVE_LEVEL2 Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/0/0/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:19 Â Â CHECKIN Â Â Â Â Â Â elec_solve_level2 Â Â Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/0/0/10 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:19 Â Â CHECKIN Â Â Â Â Â Â FEAT_ELEC_SOLVE_LEVEL3 Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/0/0/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 14:52:19 Â Â CHECKIN Â Â Â Â Â Â elec_solve_level3 Â Â Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/0/0/4 Â Â Â Â Â Â Â Â 1/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 15:59:38 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 4828:SIWAVE.EXE:@ :winx64 Â Â 7404:10.14.4.130 Â Â
2022/09/29 16:00:28 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/29 16:00:28 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2256.51560.log
2022/09/29 16:00:30 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/29 16:00:31 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 2256:SIWAVE.EXE:@ :winx64 Â Â 7376:10.14.4.130 Â Â
2022/09/29 16:00:31 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 58240@127.0.0.1.
2022/09/29 16:00:32   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  2256:SIWAVE.EXE:@ :winx64   7376:10.14.4.130  Â
2022/09/29 16:00:32 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 2256:SIWAVE.EXE:@ :winx64 Â Â 7376:10.14.4.130 Â Â
2022/09/29 17:13:24 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 2256:SIWAVE.EXE:@ :winx64 Â Â 7376:10.14.4.130 Â Â
2022/09/30 11:40:29 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 11:40:29 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15852.33597 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .15852.33597.log
2022/09/30 11:40:29 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 11:40:30 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 15852:SIWAVE.EXE:@ :winx64 Â 6904:10.14.5.83 Â Â Â
2022/09/30 11:40:30 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 65032@127.0.0.1.
2022/09/30 11:40:30   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  15852:SIWAVE.EXE:@ :winx64  6904:10.14.5.83   Â
2022/09/30 11:40:30 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 15852:SIWAVE.EXE:@ :winx64 Â 6904:10.14.5.83 Â Â Â
2022/09/30 11:40:44 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 15852:SIWAVE.EXE:@ :winx64 Â 6904:10.14.5.83 Â Â Â
2022/09/30 11:40:56 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 11:40:56 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 8020.71441 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .8020.71441.log
2022/09/30 11:40:58 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 11:40:59 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 8020:SIWAVE.EXE:@ :winx64 Â Â 7416:10.14.5.83 Â Â Â
2022/09/30 11:40:59 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 65187@127.0.0.1.
2022/09/30 11:40:59   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  8020:SIWAVE.EXE:@ :winx64   7416:10.14.5.83   Â
2022/09/30 11:40:59 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 8020:SIWAVE.EXE:@ :winx64 Â Â 7416:10.14.5.83 Â Â Â
2022/09/30 11:41:22 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 8020:SIWAVE.EXE:@ :winx64 Â Â 7416:10.14.5.83 Â Â Â
2022/09/30 11:41:36 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 11:41:36 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 11776.15068 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .11776.15068.log
2022/09/30 11:41:38 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 11:41:39 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 11776:SIWAVE.EXE:@ :winx64 Â 7384:10.14.5.83 Â Â Â
2022/09/30 11:41:39 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 65398@127.0.0.1.
2022/09/30 11:41:39   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  11776:SIWAVE.EXE:@ :winx64  7384:10.14.5.83   Â
2022/09/30 11:41:39 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 11776:SIWAVE.EXE:@ :winx64 Â 7384:10.14.5.83 Â Â Â
2022/09/30 12:00:53 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 11776:SIWAVE.EXE:@ :winx64 Â 7384:10.14.5.83 Â Â Â
2022/09/30 14:38:15 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 14:38:15 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 6136.59436 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .6136.59436.log
2022/09/30 14:38:15 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 14:38:16 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 6136:SIWAVE.EXE:@ :winx64 Â Â 7388:10.14.5.83 Â Â Â
2022/09/30 14:38:16 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 62344@127.0.0.1.
2022/09/30 14:38:17   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  6136:SIWAVE.EXE:@ :winx64   7388:10.14.5.83   Â
2022/09/30 14:38:17 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 6136:SIWAVE.EXE:@ :winx64 Â Â 7388:10.14.5.83 Â Â Â
2022/09/30 15:26:56 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 6136:SIWAVE.EXE:@ :winx64 Â Â 7388:10.14.5.83 Â Â Â
2022/09/30 15:27:13 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 15:27:13 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 18396.35041 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .18396.35041.log
2022/09/30 15:27:15 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 15:27:16 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 18396:SIWAVE.EXE:@ :winx64 Â 6900:10.14.5.83 Â Â Â
2022/09/30 15:27:16 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 59921@127.0.0.1.
2022/09/30 15:27:17   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  18396:SIWAVE.EXE:@ :winx64  6900:10.14.5.83   Â
2022/09/30 15:27:17 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 18396:SIWAVE.EXE:@ :winx64 Â 6900:10.14.5.83 Â Â Â
2022/09/30 15:27:52 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 18396:SIWAVE.EXE:@ :winx64 Â 6900:10.14.5.83 Â Â Â
2022/09/30 15:28:16 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 15:28:16 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2216.26760 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2216.26760.log
2022/09/30 15:28:18 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 15:28:19 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 2216:SIWAVE.EXE:@ :winx64 Â Â 7392:10.14.5.83 Â Â Â
2022/09/30 15:28:19 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 60245@127.0.0.1.
2022/09/30 15:28:19   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  2216:SIWAVE.EXE:@ :winx64   7392:10.14.5.83   Â
2022/09/30 15:28:19 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 2216:SIWAVE.EXE:@ :winx64 Â Â 7392:10.14.5.83 Â Â Â
2022/09/30 15:33:49 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 15:33:49 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 12212.96922 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .12212.96922.log
2022/09/30 15:33:51 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 15:33:52 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 12212:SIWAVE.EXE:@ :winx64 Â 7424:10.14.5.83 Â Â Â
2022/09/30 15:33:52 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 61821@127.0.0.1.
2022/09/30 15:33:53   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  12212:SIWAVE.EXE:@ :winx64  7424:10.14.5.83   Â
2022/09/30 15:33:53 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 12212:SIWAVE.EXE:@ :winx64 Â 7424:10.14.5.83 Â Â Â
2022/09/30 15:34:13 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 12212:SIWAVE.EXE:@ :winx64 Â 7424:10.14.5.83 Â Â Â
2022/09/30 17:07:14 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 2216:SIWAVE.EXE:@ :winx64 Â Â 7392:10.14.5.83 Â Â Â
2022/10/03 10:35:26 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/10/03 10:35:26 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 18044.23005 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .18044.23005.log
2022/10/03 10:35:26 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/10/03 10:35:27 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 18044:SIWAVE.EXE:@ :winx64 Â 6904:10.14.4.119 Â Â
2022/10/03 10:35:27 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 51354@127.0.0.1.
2022/10/03 10:35:27   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  18044:SIWAVE.EXE:@ :winx64  6904:10.14.4.119  Â
2022/10/03 10:35:27 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 18044:SIWAVE.EXE:@ :winx64 Â 6904:10.14.4.119 Â Â
2022/10/03 10:36:58 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/1/1/1 Â 18044:SIWAVE.EXE:@ :winx64 Â 6904:10.14.4.119 Â Â
2022/10/03 10:37:25 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/10/03 10:37:25 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .15192.32727.log
2022/10/03 10:37:27 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/10/03 10:37:28 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1/1/1/1 Â 15192:SIWAVE.EXE:@ :winx64 Â 7408:10.14.4.119 Â Â
2022/10/03 10:37:28 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 51980@127.0.0.1.
2022/10/03 10:37:28   CHECKOUT       electronics3d_gui        22.2 (2022.0502)       1/1/1/10         1/1/1/1  15192:SIWAVE.EXE:@ :winx64  7408:10.14.4.119  Â
2022/10/03 10:37:28 Â Â CHECKOUT Â Â Â Â Â Â FEAT_ELECTRONICS3D_GUI Â Â Â Â Â 22.2 (2022.0502) Â Â Â Â Â Â 1/1/1/1 Â Â Â Â Â Â Â Â 1/1/1/1 Â 15192:SIWAVE.EXE:@ :winx64 Â 7408:10.14.4.119 Â Â Â
Second one "licdebug.XXXX.SIWAVE_NG.EXE.222.out"
2022/09/29 16:12:35 Â Â ERROR Â Â Â Â Â Â Â Unable to connect to ansyscl on port 58240 as ansyscl is not currently running.
2022/09/29 16:12:35 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/29 16:12:35 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -aclport 58240 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2256.51560.log
2022/09/29 16:12:37 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/29 16:12:52 Â Â CONNECT_ERROR Â Â Â 16313 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 8904:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.4.130 Â Â Â Â
    ANSYSLI exited or could not read server port ansyscl..2256.51560.
    Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2256.51560.log for more information.
2022/09/29 16:12:52 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/29 16:12:52 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2256.51560.log
2022/09/29 16:12:54 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/29 16:13:09 Â Â CONNECT_ERROR Â Â Â 16309 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 8904:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.4.130 Â Â Â Â
2022/09/29 16:36:40 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/29 16:36:40 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2256.51560.log
2022/09/29 16:36:42 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/29 16:36:57 Â Â CONNECT_ERROR Â Â Â 16313 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 2744:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.4.130 Â Â Â Â
2022/09/29 16:36:57 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/29 16:36:57 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2256.51560.log
2022/09/29 16:36:59 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/29 16:37:14 Â Â CONNECT_ERROR Â Â Â 16309 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 2744:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.4.130 Â Â Â Â
2022/09/30 11:42:45 Â Â ERROR Â Â Â Â Â Â Â Unable to connect to ansyscl on port 65398 as ansyscl is not currently running.
2022/09/30 11:42:45 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 11:42:45 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 11776.15068 -nodaemon -aclport 65398 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .11776.15068.log
2022/09/30 11:42:47 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 11:43:02 Â Â CONNECT_ERROR Â Â Â 16313 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 14576:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.5.83 Â Â Â Â
    ANSYSLI exited or could not read server port ansyscl..11776.15068.
    Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .11776.15068.log for more information.
2022/09/30 11:43:02 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 11:43:02 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 11776.15068 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .11776.15068.log
2022/09/30 11:43:04 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 11:43:19 Â Â CONNECT_ERROR Â Â Â 16309 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 14576:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.5.83 Â Â Â Â
2022/09/30 15:43:53 Â Â ERROR Â Â Â Â Â Â Â Unable to connect to ansyscl on port 60245 as ansyscl is not currently running.
2022/09/30 15:43:53 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 15:43:53 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2216.26760 -nodaemon -aclport 60245 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2216.26760.log
2022/09/30 15:43:55 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 15:44:10 Â Â CONNECT_ERROR Â Â Â 16313 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 15284:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.5.83 Â Â Â Â
    ANSYSLI exited or could not read server port ansyscl..2216.26760.
    Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2216.26760.log for more information.
2022/09/30 15:44:10 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/09/30 15:44:10 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2216.26760 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .2216.26760.log
2022/09/30 15:44:12 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/09/30 15:44:27 Â Â CONNECT_ERROR Â Â Â 16308 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 15284:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.5.83 Â Â Â Â
2022/10/03 10:38:03 Â Â ERROR Â Â Â Â Â Â Â Unable to connect to ansyscl on port 51980 as ansyscl is not currently running.
2022/10/03 10:38:03 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/10/03 10:38:03 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -aclport 51980 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .15192.32727.log
2022/10/03 10:38:05 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/10/03 10:38:20 Â Â CONNECT_ERROR Â Â Â 16313 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 7228:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.4.119 Â Â Â Â
    ANSYSLI exited or could not read server port ansyscl..15192.32727.
    Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .15192.32727.log for more information.
2022/10/03 10:38:20 Â Â INFO Â Â Â Â Â Â Â Â Starting Licensing Client Proxy server.
2022/10/03 10:38:20 Â Â INFO Â Â Â Â Â Â Â Â C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl. .15192.32727.log
2022/10/03 10:38:22 Â Â INFO Â Â Â Â Â Â Â Â Started ANSYSLI server.
2022/10/03 10:38:37 Â Â CONNECT_ERROR Â Â Â 16308 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0/0/0/0 Â 7228:SIWAVE_NG.EXE:@ :winx64 Â 0:10.14.4.119 Â Â Â Â
October 3, 2022 at 6:11 pm
George Karnos
Ansys EmployeeÂ
Try setting the following System Environment Variable:
Variable:Â Â ANSYSCL_BIND_TO_LOOPBACK
Variable Value: 1Â
October 6, 2022 at 8:40 pm
eleblanc-royer
SubscriberSadly that did not change anything. Still fail with the same exact error response. Do I need to completely re-install everything?Â
- The topic ‘Simulation License Error SiWave 2022 R2’ is closed to new replies.
3236
1031
968
859
798
