September 29, 2022 at 1:12 pm
Raghuvaran Chinchedu
SubscriberHi,Â
In case of Transient analysis, does Max Iterations/ Time Step value will affect the solution.
What is its significance.
September 29, 2022 at 1:15 pm
Forum ModeratorIt's the maximum number of iterations that can be solved for a time step. If you hit the limit without converging the time step there's a good chance the solution will not be accurate. Ideally, you want a time step such that you hit the convergence criterion in 10-ish iterations, but don't do less than 2-3 to ensure the solution is actually updating.Â
September 29, 2022 at 1:19 pm
SubscriberThanks Rob, What could be the maximum limit, without much affecting the solution accuracy. Â
September 29, 2022 at 3:23 pm
Forum ModeratorOf iterations? There isn't one: the aim is to converge each time step. What you're aiming for is to get through time with as few iterations as possible. That means balancing many small time steps with few iterations with fewer large time steps with many iterations.Â
- The topic ‘Max Iterations/ Time Step’ is closed to new replies.
- affinity not set
3912
1414
1256
1118
1015
