Ansys Learning Forum Forums Discuss Simulation General Mechanical Force reaction analysis Reply To: Force reaction analysis
peteroznewman
I assume the model includes a Plasticity material model. Which one are you using? The simplest is Bilinear Isotropic Hardening. By changing the Yield Strength and Tangent Modulus, I expect you can find values that result in a force of 2N at an indentation distance of 0.19 mm.
