September 27, 2022 at 10:46 am
September 27, 2022 at 10:59 am
peteroznewman
SubscriberThe error says the model is missing a support in the Y direction. Please insert images into your reply that show the supports and loads applied to the model for further help.
September 28, 2022 at 2:22 am
September 28, 2022 at 4:06 am
reymart laranjo
SubscriberHi,
I tried it on the solid model. It worked. But is there a way to do it on surfaces only?
rgds, -
September 28, 2022 at 12:30 pm
peteroznewman
SubscriberAttach a Modal analysis to the Static Structural model of the surface. Apply the same constraints to the Modal analysis. Solve the Modal and see if you have almost zero natrual frequencies. Watch the animations of those to determine which surface is not connected.
Open the Surface geometry in SpaceClaim and on the Workbench tab, click the Share button. This will cause all coincident geometry to share nodes. Then rerun the Modal and you should get a non-zero first mode frequency.
September 29, 2022 at 2:44 am
reymart laranjo
Subscriber -
September 29, 2022 at 3:05 am
September 29, 2022 at 10:01 am
peteroznewman
SubscriberHi Reymart, glad it’s working now.
ANSYS has a module called AQWA that makes it easier to simulate structures such as a ship or barge being acted on my wave motion. I have never used it. I expect it comes with some tutorials.
- The topic ‘Soler Pivot warnings or errors have been encountered during the solution.’ is closed to new replies.
5744
1305
