September 27, 2022 at 1:51 amlancerSubscriber
Is the flux type feature available in ANSYS 2021 R1, if yes, where is it?Â
September 27, 2022 at 3:07 pmRobForum Moderator
The what?Â
September 28, 2022 at 2:09 am
September 28, 2022 at 6:06 amNikhil NAnsys Employee
Hello,Â
To make the option appear:Â
1: Set the fluid material as compressible (Ideal gas model). Change flux type (ansys.com)
2: Enable beta features. 17.6. Roe Flux-Difference Splitting Scheme in the Pressure-Based Solver (ansys.com)
Nikhil
September 28, 2022 at 6:07 amNikhil NAnsys Employee
If you are not able to access the links, refer to this forum discussion: How to access Ansys Documentation - Generic
Viewing 4 reply threads
- The topic ‘SOLUTION METHOD – FLUX TYPE’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Script error Code: 800a000d
- Cyclone (Stairmand) simulation using RSM
- Fluent fails with Intel MPI protocol on 2 nodes
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
543
523
225
209
