Ansys Learning Forum Forums Discuss Simulation Fluids error:when making a remote call to participant Solution Reply To: error:when making a remote call to participant Solution
Rahul
Hi, Please examine the output files for each solver to look for clues to what happened. For Fluent, look at the transcript .trn file. For Mechanical, look at the .out file. For CFX, look at the .out file. Also, look at the System Coupling log file, .scl. You can also try re-running the case and stopping it just before the timestep when it throws error, then examine the mesh in Fluent or CFD-Post to get more clues. Hope this helps you. please let me know if you have any questions. Regards,
