Ansys Learning Forum Forums Discuss Simulation Fluids Will the flow from a room fan be laminar or turbulent? Reply To: Will the flow from a room fan be laminar or turbulent?
Melanie Butts
Thank you for your responses.
Keyur Kanade I looked at the link, and it deals with critical Reynolds numbers for internal flow. I should probably clarify that my box domain has pressure boundary conditions on all sides, and no walls. For this situation I would need to use a different critical Reynolds number than can be used for pipe flow, correct?
Thank you
