Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Calculate stress based on two 3d model; initial 3D model and deformed 3D model. › Reply To: Calculate stress based on two 3d model; initial 3D model and deformed 3D model.
September 22, 2022 at 10:28 am
Hi @Janggyun,
You can create a 3D model using the STL file (generally this format is output by scanners) and then perform an analysis on the same.
Ashish Khemka
