3D Design
3D Design
Error when making parts independent
    • jonl
      Hi!
      I have an assembly imported from Creo where two parts are identical (the purple flanges). In order to move them separately, I need to make them independent. This usually works fine, but this time i get this error:
      "The inter-doc reference would create a cyclic dependency at the document level."
      How can I resolve this? Where can I find (and delete) references?
    • asfand ali
      Same Problem Kindly Share Solution
    • jonl
      I deleted one of the parts and made a new copy (by holding CTRL while draging one handle on the move tool)
  • The topic ‘Error when making parts independent’ is closed to new replies.
