Ansys Learning Forum Forums Discuss Simulation General Mechanical How to use script to run the cfile for creating k file? Reply To: How to use script to run the cfile for creating k file?
igandiko
What does job_command.solver show in LSPP 1.1 directory? What happens if you manually run this command file through a terminal?
