TAGGED: batch-command, fluent-coupling, fluent-edem, tui
September 21, 2022 at 11:13 am
fatemeh.hosseini
SubscriberHello every body,
I want to do CFD-DEM simulation by coupling EDEM and Fluent in a cluster without GUI.
I did only a simple Fluent simulation on Fluent TUI before and it is the first time that I want to do the simulation of EDEM and Fluent in a batch mode.
About coupling these two software and the commands that I should use such as connecting the interface, synchorising EDEM,....I have no idea.
Is there any refrences or website that help me about the Fluent TUI commands?
Fatemeh -
September 21, 2022 at 1:31 pm
Forum ModeratorThe easier method is to set everything up live via the GUI and then trigger the run on the cluster using a journal. Does EDEM control the process, Fluent, or a coupling tool?Â
September 21, 2022 at 2:17 pm
fatemeh.hosseini
SubscriberYou are right. When I wanted to run a CFD simulation I set all parameters in my computer and only run it on cluster. but now, I should use coupling tools and when EDEM and Fluent connect together, new features will apear in Fluent and should be set.
So I should set them after coupling in a Fluent TUI.
Most of the setting should be done in Fluent,So Fluent control the process.Â
Fatemeh
September 21, 2022 at 2:24 pm
Forum ModeratorAnd you can't set up both parts on your machine then send to the cluster?Â
September 21, 2022 at 2:31 pm
fatemeh.hosseini
SubscriberNo.
This is the whole process:
I should save fluent case (from fluent) and dem file (from EDEM) separelaty.
Then a load edem journal should be read in fluent.
The last step will be setting dem parameters and model in Fluent.Â
Fatemeh
September 21, 2022 at 2:41 pm
Forum ModeratorIt's potentially not that simple, the author can't remember if the commands have a TUI equivalent, and we can't provide information beyond what's in the manual. You may need to use the GUI.Â
- The topic ‘EDEM-Fluent on batch mode (computers without GUI)’ is closed to new replies.
- affinity not set
4167
1487
1363
1194
