Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Mesh on Setup Parallel Fluent › Reply To: Mesh on Setup Parallel Fluent
September 20, 2022 at 10:39 am
You've also not shared topology so the boundary between the two volumes is non-conformal. That may make the set up and display a little more complicated than necessary.Â
