Ansys Learning Forum Forums Discuss Simulation Electronics Defining Heat Profile Reply To: Defining Heat Profile
Nikhil Tamhankar
Assuming you are using Classic Icepak, you can create a spatial power profile on Source objects by choosing the Surface/Volume Flux in the Thermal Condition in object properties. There you should see a Profile option to add the X, Y, Z co-ordinate lengths and the power values. Same can be done on 3D blocks by going to Basic Parameter settings, and using the Spatial Profile option there. If you want to specify Temperature, then using a wall object with temperatuer profile is the solution. Please search these options in the user guide for more details. Hope this helps.Â
