September 17, 2022 at 5:21 pm
kh_d
SubscriberHello everyone,
I want to use DesignXplorer to study the change in material properties. I have to save all the files in each run because they are required for substructuring. There are going to be more than 2000 runs, and I want to know if it is possible to delete all the files after each run not to have that many folders saved.
I have found /DELETE command but that seems to work only for a single file with a certain extension.Â
Any hints about how I can solve this problem are appreciated.
Thank you very much in advance.
September 18, 2022 at 11:15 am
- The topic ‘Deleting all the files in the directory with apdl’ is closed to new replies.
1859
1403
1257
