September 16, 2022 at 8:30 pm
mctom0518
SubscriberI have two computers that have 2022R2 version of the Ansys Fluids Package and when I try to run DesignModeler, both computers behave differently when sketching.Â
When I sketch a circle, for example, the Display Plane option toggles off automatically, causing the axis planes to disappear in the Graphics Window. My other computer does not have this issue and both computers are the same model and have the same setup, so I am not sure what the difference is at this moment. I was wondering if anyone else has run into this issue and have determined a solution to this.
Thank you for the help!
September 19, 2022 at 4:29 am
September 19, 2022 at 5:46 pm
mctom0518
SubscriberHello Keyur and thank you for your time and help.
The issue is difficult to describe but I have attached a video link:
https://youtu.be/0BguD5H5wdg
Basically, when I try to draw a sketch, the entire model just disappears and then reappears intermittently. I am not sure how to debug this issue.Â
September 21, 2022 at 5:00 am
Keyur Kanade
Ansys EmployeeThank you for video. This is nothing to do with DM. You will need to check the hardware supported. Please check following link.Â
Platform Support and Recommendations | Ansys
If you have any quesitons about hardware, you can post it under installation category.Â
Keyur
September 30, 2022 at 8:34 pm
mctom0518
SubscriberI determined the issue and the cause was that my computer did not have the NVIDIA drivers enabled. Thank you!
- The topic ‘DesignModeler Display Plane keeps automatically disabling’ is closed to new replies.
5799
1305
