Ansys Learning Forum Forums Discuss Simulation Fluids temperature spike in Natural Convection using Ansys MSMD Battery Module Reply To: temperature spike in Natural Convection using Ansys MSMD Battery Module
Murari Iyengar
Are you using any expressions or UDFs? Kindly check your BCs and setup. If you are not getting a temperature profile, then most likely the BC is incorrect.
