TAGGED: ansys-apdl, Eigenfrequencies, natural-frequency, verification
September 15, 2022 at 6:47 am
julius.langenhorst
SubscriberHello,
I have a complex truss structure that has the following natural frequencies. Some of them are multiples and some are very close to the multiples. How can I verify mathematically that I really have repeated eigenfrequencies and not some frequencies that are just close to each other?
13252.43697076
13253.72670625
13253.72670625
13319.90610080
13319.90610080
13319.90610080
15125.04970060
15125.04970060
15125.05037702
17822.02177338
17822.65139503
17822.65139503Is it possible to recognize repeated eigenfrequencies from the values alone? If yes, at which decimal place do numerical errors start to falsify the results?
Thank you for your help!
September 15, 2022 at 11:14 am
peteroznewman
SubscriberIf the structure has two planes of symmetry (both geometric and boundary conditions), then you expect repeated eigenfrequencies because the structure will move in the XY plane for one and move in the YZ plane for the repeated frequency due to those being the planes of symmetry. If the structure, including the mesh, is not perfectly symmetric, then a small difference can be introduced between the two planes, but I would still call that a repeated eigenfrequency.
It’s possible to have two very close frequencies that have totally different mode shapes. You can see that when you animate the two modes. You can’t tell from the values alone, you need to look at the mode shape.
September 15, 2022 at 4:44 pm
julius.langenhorst
SubscriberThank you for your answer!
I'll have a look at animating the modes. But it's save to say that frequencies which are equal up to the 6th decimal place or so are repeated eigenfrequencies?
September 15, 2022 at 5:10 pm
peteroznewman
SubscriberYes, that is a safe assumption.
September 19, 2022 at 11:54 am
julius.langenhorst
SubscriberThank you!
- The topic ‘Verification of repeated eigenfrequencies’ is closed to new replies.
6795
1343
1152
