Photonics
Photonics
Issue with Importing source
    • U Abinash Patro
      When I am trying to import a radially polarised source(generated the .MAT file from a code I got in lumerical website) using the import source option , Initially I am able to visualise the distribution of  electric field vectors just after impoting the data , but when I try to apply and ok while setting up the simulation and running it, I am unable to get any electric field data. Can anyone can comment regarding this?
    • Guilin Sun
      Do you want to get the importd source data, or want to visualize the source data?  Do you find any result in other monitor? Please make sure you save it correctly.  you can close the import tab and reopen, then visualize the data to see if it is normal.
    • U Abinash Patro
      First I import the source and visualise it, everything seems fine i.e; I can see the electric field vectors in a radially outward way for a radially polarized source. Now just after clicking 'OK' for saving the data in the simulation, I reopened the source properties and clicked on visualise the data but it is showing source not imported.
      Also after I run the simulation, I tried to see monitor data and there the electric field was 0.
    • Guilin Sun
      I believe you need to update the FDTD version to the newest 2022R2.2.
      I tested and did not find any issue regarding to the source import.
      You may need to have a clean installation: https://optics.ansys.com/hc/en-us/articles/5613618572947-Fixing-installation-or-license-activation-issues
      clear all related folders, including hidden folders, restart your computer, reinstall, and test again.
    • Binbin Nie
      I met the same issue. I wonder if the problem has been solved. If yes, may I know the solution ?
    • Guilin Sun
      Please follow the previous suggestion.
Viewing 5 reply threads
  • The topic ‘Issue with Importing source’ is closed to new replies.
