Electronics
Electronics
Capacitance extraction with extension Piezo and MEMs
    • chengyan hu
      Hello everybody,
      I have now a problem with the capacitance extraction in the extension of Piezo and MEMS.
      I followed all the sequence in the tutorial until this step: Insert the ''capacitance post processing''. In the definition column there is always no option, and only remains blank. But in the tutorial the capacitance extration from the analysis setting can be chosen.
      All other options for the solution are good, so i am not sure where the problem could be.
      The version i used is 2022  R1 student version, and the extension i used is the version for 2020 (seems the newest).
      Looking forward for your answer.
      Best regards
      CH
    • chengyan hu
      Reinstalled and fixed
    • ashish.khemka
      Thanks @Chengyan Hu for the update. Was reinstalling the fix? If you did follow any other steps then please feel free to share the same as other members too will benefit from this.
      Ashish Khemka
    • Joseph Ting
      Dear Chengyan,
      Can u assist me in the capacitance extraction project by leaving your contact number for me in order to contact you?Thank you
    • Joseph Ting
      Dear Chengyan, Can u assist me in the capacitance extraction project by leaving your contact number for me in order to contact you?Thank you
Viewing 4 reply threads
  • The topic ‘Capacitance extraction with extension Piezo and MEMs’ is closed to new replies.
