Negative load multiplier buckling
    • tumulpurwar
      I just want to be confirmed, Negative load multiplier in Ansys means Tension?
      Negative load multiplier means the structure would buckle when the applied load is in the opposite direction.
      If your applied load was to compress the structure, then yes the opposite direction is tension.
    • tumulpurwar
      Thanks Peter
  • The topic ‘Negative load multiplier buckling’ is closed to new replies.
