TAGGED: licensing, research-license, teaching-license
August 31, 2022 at 9:07 pm
rachael.auch
SubscriberCan someone shed some light on how one can check out an Academic Teaching Mechanical and CFD license versus a Research Mechanical and CFD license? We have both teaching and research licenses hosted on the same license server. We have some students that need to use the teaching licenses for a class and I can't seem to find a way to keep them from dipping into our research licenses, or a way to choose between which licenses they will use. If anyone can provide some information on how to do this, I'd really appreciate it. I am hoping it doesn't involve splitting/rehosting the licenses. Thanks.
September 6, 2022 at 12:43 pm
George Karnos
Ansys EmployeeOther than below, the only other path forward is to separate the teaching and research license to different servers.The user can pick which server to check out licenses from.ÂThe process of allowing users to select Teaching/Research licenses since license preferences have now been retiredis as below.ÂI would perform this when usage is not expected and also would set the LM_PROJECT on the client first.Once the options file is in place users without LM_PROJECT set will not be able to check out licensesÂOn the client machines, you would need to set the environment variable: LM_PROJECTFor teaching: set LM_PROJECT=teaching  (to match the PROJECT statement in the options file(in the include line).For Research: set LM_PROJECT=research  (to match the PROJECT statement in the options file(in the include lineÂThe options file will need to be used to distinguish teaching from research and associate them with PROJECT namesAs an example:ÂFor Teaching:The options file line would be as follows:INCLUDE ansys:VENDOR_STRING="customer:00000054 tp:at" PROJECT teachingOn Client: set LM_PROJECT=teachingÂAn include line would need to be added for EVERY Increment line with VENDOR_STRING="customer:00000054 tp:at"ÂThen, for Research:Options file lines would be as follows:INCLUDE ansys:VENDOR_STRING="customer:00000054 tp:a" PROJECT researchOn Client: set LM_PROJECT=researchAgain, an include line would need to be added for every Increment line with VENDOR_STRING="customer:00000054 tp:a"ÂÂIf the user needs the ability to switch between the 2 on the client, the user would create wrapper scripts to set LM_Project and then launch whatever programÂthey need to run.ÂÂExample:Âsetenv LM_PROJECT teachingrunwb   (include the path or change the program name)(Linux)
"C:\Program Files\ANSYS Inc\ANSYS Student\v211\Framework\bin\Win64\runwb2.exe" (Windows)ÂPlease let me know if you have questions.
- The topic ‘How to check out a teaching license vs. research license?’ is closed to new replies.
1311
