August 16, 2022 at 7:58 pm
ssaeidab
SubscriberHi all,
I wanted to use the ANSYS Maxwell Optimization algorithm for motor design. I wanted to maximize the Torque and keep the ripple below 5%. But it does not let me define these two goals. I was wondering if you had any suggestions and help me with this.
Thanks
August 17, 2022 at 11:54 am
NKC
Forum ModeratorHi ssaeidab,
When you say "it does not let me define these two goals"
What and how are you exactly defining these?Â
if you can share some screenshots it will be useful to understand the problem better.
Regards,Navya
August 26, 2022 at 3:19 pm
- The topic ‘Ansys Maxwell Optimization’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1220
1118
1015
