Ansys Free Student Software
“ANSYS Workbench can’t open” Post is Access Denied
    • fakihatu.19023
      Why my post on "ANSYS Workbench can't Open" is access denied? My problem is not yet finished. Can you repeat your reply again? Because I can't open my last post. My last reply is about running "set>set.txt" in command prompt
    • fakihatu.19023
      Below is the result of running "set>set.txt" in the command prompt
      ALLUSERSPROFILE=C:\ProgramData
      ANSYS222_DIR=C:\Program Files\ANSYS Inc\v222\ANSYS
      ANSYSLIC_DIR=C:\Program Files\ANSYS Inc\Shared Files\Licensing
      APPDATA=C:\Users\LENOVO\AppData\Roaming
      AutInstLog=C:\ProgramData\Siemens\Automation\Logfiles\Setup\
      AWP_LOCALE222=en-us
      AWP_ROOT222=C:\Program Files\ANSYS Inc\v222
      CADOE_LIBDIR222=C:\Program Files\ANSYS Inc\v222\CommonFiles\Language\en-us
      ChocolateyInstall=C:\ProgramData\chocolatey
      ChocolateyLastPathUpdate=132852264424065190
      CommonProgramFiles=C:\Program Files\Common Files
      CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
      CommonProgramW6432=C:\Program Files\Common Files
      COMPUTERNAME=LAPTOP-5EHLOELC
      ComSpec=C:\WINDOWS\system32\cmd.exe
      DriverData=C:\Windows\System32\Drivers\DriverData
      F_EM64T_REDIST11=C:\Program Files (x86)\Common Files\Intel\Shared Files\fortran\
      GPU_FORCE_64BIT_PTR=0
      GPU_MAX_ALLOC_PERCENT=100
      GPU_MAX_HEAP_SIZE=100
      GPU_SINGLE_ALLOC_PERCENT=100
      GPU_USE_SYNC_OBJECTS=1
      HOMEDRIVE=C:
      HOMEPATH=\Users\LENOVO
      ICEMCFD_ROOT222=C:\Program Files\ANSYS Inc\v222\icemcfd
      ICEMCFD_SYSDIR=win64_amd
      INTEL_DEV_REDIST=C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
      IRONRUBY_11=C:\Program Files (x86)\IronRuby 1.1\bin
      JAVA_HOME=C:\Program Files\Zulu\zulu-8
      LOCALAPPDATA=C:\Users\LENOVO\AppData\Local
      LOGONSERVER=\\LAPTOP-5EHLOELC
      LServOpts=-l "C:\Program Files (x86)\AspenTech\SLMServerLogs\lserv.log" -z 5m -lfe 2 -sbm 4
      LSHOST=LAPTOP-5EHLOELC
      LSTC_LICENSE=Ansys
      MIC_LD_LIBRARY_PATH=C:\Program Files (x86)\Common Files\Intel\Shared Libraries\compiler\lib\intel64_win_mic
      MSMPI_BENCHMARKS=C:\Program Files\Microsoft MPI\Benchmarks\
      MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
      NUMBER_OF_PROCESSORS=12
      OMP_NUM_THREADS=12
      OneDrive=D:\OneDrive - Institut Teknologi Sepuluh Nopember
      OneDriveCommercial=D:\OneDrive - Institut Teknologi Sepuluh Nopember
      OneDriveConsumer=D:\OneDrive
      OS=Windows_NT
      OSLoader_FTP_Timeout=120
      Path=C:\Program Files\Microsoft MPI\Bin\;C:\Program Files (x86)\Rockwell Software\RSCommon;C:\Program Files (x86)\SIEMENS\S7-PCT\bin;C:\Program Files\Common Files\Siemens\Automation\Simatic OAM\bin;C:\Program Files (x86)\Common Files\Intel\Shared Files\fortran\bin\Intel64;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;D:\Applications & Games Data\MATLAB\R2020a\bin;C:\Program Files\MATLAB\R2020a\bin;C:\PROGRA~1\MATLAB\R2020a\bin;C:\Users\LENOVO\AppData\Roaming\Python\Python38\Scripts;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Gradle\gradle-6.6-all\gradle-6.6\bin;C:\Program Files (x86)\Common Files\AspenTech Shared\;C:\Program Files\Common Files\AspenTech Shared\;C:\Program Files\dotnet\;C:\Program Files\CMake\bin\bin;C:\Program Files\Graphviz\bin;D:\Applications & Games Data\MATLAB\MATLAB Runtime\v94\runtime\win64;C:\Program Files\nodejs\;C:\ProgramData\chocolatey\bin;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\PKWARE\pkzipc;C:\Program Files (x86)\Common Files\Rockwell\;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler\;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler\;C:\Program Files (x86)\IronRuby 1.1\bin;C:\Users\LENOVO\AppData\Local\Programs\Python\Python38\Scripts\;C:\Users\LENOVO\AppData\Local\Programs\Python\Python38\;C:\Users\LENOVO\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\LENOVO\AppData\Local\Programs\Python\Python39\;C:\Users\LENOVO\AppData\Local\Microsoft\WindowsApps;C:\Users\LENOVO\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\LENOVO\AppData\Roaming\npm
      PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
      PROCESSOR_ARCHITECTURE=AMD64
      PROCESSOR_IDENTIFIER=AMD64 Family 23 Model 96 Stepping 1, AuthenticAMD
      PROCESSOR_LEVEL=23
      PROCESSOR_REVISION=6001
      ProgramData=C:\ProgramData
      PROMPT=$P$G
      PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\PowerShell\Modules\
      PUBLIC=C:\Users\Public
      P_SCHEMA=C:\Program Files\ANSYS Inc\v222\AISOL\CADIntegration\Parasolid\PSchema
      RABBITMQ_CONFIG_FILE=C:\Program Files\AspenTech\aspenONE V12.0\rabbitmq
      SCPLMD_LICENSE_FILE=C:\Program Files (x86)\Common Files\Honeywell\OLGAS\license.dat
      Simatic_OAM=C:\Program Files\Common Files\Siemens\Automation\Simatic OAM
      Simatic_OAM_DATA=C:\ProgramData\Siemens\Automation\Simatic OAM
      SoS_debug_exe=C:\Program Files\ANSYS Inc\v222\optiSLang\sos\sos_console.exe
      SoS_exe=C:\Program Files\ANSYS Inc\v222\optiSLang\sos\sos.exe
      SoS_install_dir=C:\Program Files\ANSYS Inc\v222\optiSLang\sos
      SW_SIM_HYDRA=C:\Program Files\Common Files\SolidWorks Shared\Simulation Worker Agent\
      SW_SIM_MPIT=INTELMPI
      SW_SIM_TEMP=C:\ProgramData\SOLIDWORKS\SW_net_sim_temp\
      SystemDrive=C:
      SystemRoot=C:\WINDOWS
      TEMP=C:\Users\LENOVO\AppData\Local\Temp
      TMP=C:\Users\LENOVO\AppData\Local\Temp
      USERDOMAIN=LAPTOP-5EHLOELC
      USERDOMAIN_ROAMINGPROFILE=LAPTOP-5EHLOELC
      USERNAME=LENOVO
      USERPROFILE=C:\Users\LENOVO
      USE_SLM=1
      VBOX_HWVIRTEX_IGNORE_SVM_IN_USE=1
      VRAY_GPU_PLATFORMS=amd accelerated parallel processing gfx902 gpu index0;nvidia cuda geforce gtx 1650 gpu index0;
      windir=C:\WINDOWS
  • The topic ‘“ANSYS Workbench can’t open” Post is Access Denied’ is closed to new replies.
