August 9, 2022 at 12:21 pm
Md_Salem
SubscriberHi,
I am carrying out optimization process using Ansys 2022R1 workbench for geometric configuration under harmonic load.
My concern is to apply the harmonic load at the frequency of the first mode shape ( first natural frequency) which can be obtained from pre-modal analysis as a value.
I wonder if i can make the Ansys repeat the modal analysis after optimization is done (for the new geometric configuration) Â and ahence extract the new first natural frequency , then repeat the optimization with the new load frequency and so on ?
In other words, can I implement the harmonic analysis to go under first natural frequency (or any aother selected natural frequency) directly from the modal analysis ?Regards
August 10, 2022 at 2:27 pm
Chandra Sekaran
Ansys EmployeeWithin the Mechanical GUI the frequency value at which to carry out the harmonic analysis has to be typed in. There is not a way to use the first natural frequency from a modal analysis. However you can potentially do this using APDL command snippets. I am thinking you can do the following:
- in the modal analysis in Post1 *GET the first natural frequency. Write this to a file (*CFOPEN, *VWRITE, *CFCLOSE) to a known folder, say, d:\test
- In the harmonic analysis read this frequency from the file (*VREAD) and use HROPT to apply the frequency range with NSUB,1.
August 15, 2022 at 10:03 am
August 23, 2022 at 1:05 pm
Md_Salem
SubscriberHello Chandra,
I did the first part of the solution (get the 1st frequency and write it as a parameter to *.txt file)Â
Now I have a problem with workbench harmonic analysis, which is how to force the solver to bypass the  (analysis setting) of workbench solver and read the analysis setting from my APDL macro code ?
*VREAD,Fd,MODES_F,TXT,E:\ Â !(Fd parameter for frequency & MODES_F.txt is the file)
(F12.4) Â Â Â Â Â Â !(fortran format)
HROPT,FULL Â
HROUT,ON
LUMPM,0Â
!* Â
EQSLV, ,0, Â
PSTRES,0
!* Â
HARFRQ,0,Fd, Â Â
NSUBST,1, Â Â
The workbench keeps telling me (invalid "Range Maximum") even if I put numerical value directly instead of Fd.
I think that the problem is in the (Analysis Setting) table which has to be filled up with values or deleted or doing a bypass to enforce workbench solver to take the analysis setting form the APDL macroRegards
- The topic ‘harmonic-based optimization’ is closed to new replies.
6485
