July 25, 2022 at 5:56 pm
egano
SubscriberHi,ÂI am using ls-prepost V:4.6.22 and need double precision for a project I am doing. I see options for downloading a newer version that uses double precision but am wondering if this is a paid application or if there is a free download that I can add-on to my current version (V4.6.22). This is the only time I will need double precision and would rather not pay for the software if I don't need to.ÂReasoning: When running my project I receive the following error message:Error 60022 (IMP+22)   LS-DYNA Implicit is not supported in single precision.   Please switch to DOUBLE Precision (I8R8) version.ÂThank you! -
July 25, 2022 at 9:49 pm
Reno Genest
Ansys EmployeeHello,
LS-PrePost is free and you can download the latest version here:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/4.9/
But, the error message that you are getting has nothing to do with LS-PrePost. You need need a double precision LS-DYNA solver to run implicit. You can download double precision solvers (any revision, but the latest is R13.1) here:
https://lstc.com/downloader/page.html
username: user
password: computer
Let me know how it goes.
Reno.
July 29, 2022 at 8:35 pm
July 29, 2022 at 8:47 pm
Reno Genest
You don't need to have everything in the same path. You can have your model somewhere and all your LS-DYNA solvers in a different location.
Have you specified the license server information in the license menu in LS-RUN?
If so, you should be able to see the licenses when clicking on the License Info tab.
Is this the first time you use LS-RUN?
Reno.
August 10, 2022 at 9:44 pm
egano
SubscriberHi, sorry for a late reply. I have decided to use my school grid to prevent taking longer for this project. I have worked out the licensing and am now getting error 60105:
*** Error 60105 (IMP+105)
   *         -  ERROR  -           *
   *     Error code    2 returned from    *
   *   Sparse Iterative Linear equation solver.   *
   **************************************************I am also seeing an alert saying to change my memory setting to 1M, which I assume is in my jobfile. I changed this and am still getting the same alert and error.
Thanks!
August 10, 2022 at 9:48 pm
Reno Genest
Can you start a new post for the above error? It is not related to LSPP and I am not sure what is causing it.
Thanks.
Reno.
- The topic ‘lspp single precision to double precision help’ is closed to new replies.
6344
