July 20, 2022 at 6:12 pm
gary
SubscriberI have a netlist of a circuit that I can run under Nexxim. It requires accurate transistor models. However, I want to include it as part of an interface to a Maxwell Model (transient). It seems in order to do this, I must work in Twin Builder. When I make a subcircuit in Twin Builder, it runs Berkeley SPICE (instead of Nexxim). Unfortunately, Berkeley SPICE does not support the most important transistor model parameters. Hence, the circuit (netlist) does not run properly in Berkeley SPICE. Using standard library components (transistors, etc...) the result is the same. Is there anyway around this?
Is there a way to run Nexxim with Twin Builder subcircuits? I am at a dead end.
Thanks
July 26, 2022 at 1:21 pm
Dan Dv
Ansys EmployeeHello Gary,
Unfortunately Nexxim and Twin Builder are not compatible with each other. So no we can't have a Nexxim circuit block running inside of Twin Biulder or vice versa.Â
January 18, 2023 at 11:14 am
Sebastiano Santarpia
SubscriberI have the same problem. I have an Igbt model in simplorer, and I want make DC sweep, but the tool is only available in circuit tool, not simplorer? any hint?
January 23, 2023 at 9:31 pm
Dan Dv
Ansys EmployeeUnfortunately we cannot run Simplorer model in the Circuit tool. You would have to obtain an HSPICE or PSPSICE syntax model of the IGBT in order to run the DC sweep in Circuit.Â
- The topic ‘Nexxim/SPICE/ Twin Builder’ is closed to new replies.
3597
1283
1107
1068
978
