July 14, 2022 at 2:03 pm
azarandi
SubscriberI am running a static structural simulation and it is giving me the following error
"The maximum contact stiffness is too big. This may affect the accuracy of the results. You may need to scale the force unit in the model."
How can I check and change the contact stiffness ?
July 15, 2022 at 12:37 pm
peteroznewman
SubscriberIs this an error? It seems like it is a warning.
What units did you solve in? If you solved in the length unit of m, try solving in mm to see if that eliminates the warning.
If the warning goes away, do you still want to change the contact stiffness?
July 15, 2022 at 3:29 pm
azarandi
SubscriberHi Peter,
It is a warning and it got fixed as you helped.
Thanks
- The topic ‘Maximum contact stiffness warning’ is closed to new replies.
1305
