Validation of contact model
    • marco.ballotta.2
      Is there a way to validate the results of a simulation involving contacts?
      I have obtained some stress results that seem realistic but how can I be sure they are correct?
      They come from two bodies in contact, so how do I know the contact is modeld in the correct way? Thank you
    • Naresh Patre
      Hello @marco.ballotta.2
      Please check out below Ansys Innovation Course on Reviewing Results - Validation and Insight Using Ansys Mechanical which covers topics related to reviewing stress analysis results.
      Results Insight - ANSYS Innovation Courses
    • marco.ballotta.2
      Thank you.
      I am also checking out the course on contact mechanics.
      Is it also useful to solve a simple contact problem and confront the results with the analytical solution, so to use the same contact settings for larger model that doesn't provide analytical solution? Hope I made myself clear.
  • The topic ‘Validation of contact model’ is closed to new replies.
