July 5, 2022 at 5:49 pm
alessandro.borghi
SubscriberHi,
I need to calculate the are of a specific surface which varies due to a load. The geometry is 3D. I have tried with APDL command but I only managed to extract volume of the underlying elements rather than surface area. I was relatively successfull on planar structure meshed with shell elements. I have tried it on a simple 1mm3 cube undergoing 1% strain but no luck. Any idea on how to do it?
July 6, 2022 at 2:56 pm
Aniket Chavan
Forum ModeratorPlease check if arnode(N) function helps you in this case.
-Aniket
- The topic ‘calculate surface area’ is closed to new replies.
