June 30, 2022 at 6:01 pm
yrong5
SubscriberDear Advanced Ansys HFSS users:
I just started learning Ansys if I am asking something wrong please let know.Â
Currently I am working on a project trying to understand RF waves (6 - 8 GHz and 60 GHz) interaction with layered human body.Â
There are two questions our customer is longing to know,
1) penetration depth 2) which body parts comtributing most to the signal return
Based on the requirements, I think we should use transmittance for 1) and reflectance for 2). Seems aborbance is for SAR type analysis and is not a immediately concern for us.
Given the RF source, phantom model and discretized 3D space, will the HFSS provide the three parameters: absorbance, transmittance and reflectance values?
Free feel to lecture me if I am totally wrong,Â
Thanks in advance.Â
August 1, 2022 at 4:16 pm
CB
Ansys EmployeeHello yrong5,
I would think that Specific absorption rate (SAR) which is the rate that EM energy is absorbed by the tissue is an important value to know. The signal that is absorbed or reflected is fully depenedent on the transmitted signal and the material tissue it encounters. Depending on the level of analysis you are doing you can use a generic phantom or purchase more complex human body models for use inside of HFSS. The purchased human body models differ by complexity - how much model geometry detail or tissue detail you are interested in. In short yes HFSS will supply you with absorbance, transmittance and reflectance results.Â
Charlotte
- The topic ‘Absorbance, transmittance and reflectance values in discrete 3D space’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3912
1414
1256
1118
1015
