June 15, 2022 at 8:07 am
shivaji.deshmukh
SubscriberWhat will be the effect of if Point mass behavior changed from Rigid to Deformable or Coupled in the modal analysis? -
June 16, 2022 at 5:50 am
Erik Kostson
Ansys EmployeeIf you search the internet there are lots of posts on the topic of rigid and deformable remote points, or remote forces or point mass (it does not matter if it is one of this 3, the conecpt of deformable and rigid is still the same).
https://www.google.com/search?q=rigid+vs+deformable+and+ansys&rlz=1C1GCEB_enGB865GB865&sxsrf=ALiCzsbxo53X_JnoBjMQ8DXOSP4Ni1IM-Q%3A1655358472873&ei=CMSqYvj3NJeO8gLEx5aQDA&ved=0ahUKEwj4m4HuorH4AhUXh1wKHcSjBcIQ4dUDCA4&uact=5&oq=rigid+vs+deformable+and+ansys&gs_lcp=Cgdnd3Mtd2l6EAM6BwgAEEcQsANKBAhBGABKBAhGGABQzB9YlzRg5zVoA3ABeAGAAVmIAekIkgECMTiYAQCgAQHIAQjAAQE&sclient=gws-wiz
June 16, 2022 at 9:56 am
shivaji.deshmukh
SubscriberIn my analysis I have considered bushing joint at front because bushing is going to use in actual condition, so i have added the stiffness of the bushing in that joint. See the image below. But problem is when I considered deformable mass point I get lower frequency value and if I consider rigid mass point the I get higher frequency value. I don't think so it is same behavior.Â
- The topic ‘Point mass behavior in the modal analysis.’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1461
1287
1124
