Ansys Learning Forum Forums Discuss Simulation General Mechanical What is the behavior of geometry attached to a point mass in stress analysis? Reply To: What is the behavior of geometry attached to a point mass in stress analysis?
shanmukhvaranasi
Thanks for the reply ekostson.
What is the difference between coupled, rigid and deformable options for point mass? If I would like to attach a rigid body as a point mass to a flexible bracket with geometry scoped at the mounting holes for the bracket, which behavior is appropriate?
Thanks in advance.
