Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › how to get the node id of the maximum stress/strain using ACT? › Reply To: how to get the node id of the maximum stress/strain using ACT?
April 20, 2022 at 8:19 am
akashp81995
Hi @akhemka
Thank you for your response. I think it would help me do it manually.
I am trying to get the node ID with the maximum stress value using Python for ACT. And I might have to get the same for hundreds of results. So using this method suggested by you would create hundreds of files. In order to avoid this, I am looking for a Python API/Command that would give me the node ID with the maximum stress value without having to export the stress results.
Thanks in advance Akash Purushothaman
