Ansys Learning Forum Forums Discuss Simulation Fluids problem with residuals Reply To: problem with residuals
Murari Iyengar
Hi _1 billy This issue can occur due to poor mesh quality/incorrect setup. Have you checked mesh quality? Make sure min Orthogonal quality 0.1 and Max Skewness < 0.98. If mesh quality is good, please check the setup to see if you are using the appropriate model and boundary conditions for your simulation.
You can find more information below.
Mesh quality : Check Mesh Quality (ansys.com)
Fluent turbulence models : 13.2. Choosing a Turbulence Model (ansys.com)
Boundary conditions: 7.4. Boundary Conditions (ansys.com)
