Ansys Learning Forum Forums Discuss Simulation General Mechanical How can I mesh/couple edge of a shell element to a beam element surface? Reply To: How can I mesh/couple edge of a shell element to a beam element surface?
peteroznewman
What is the diameter of the beam and the thickness of the shell. If they are the same material and the dimensions are not so different, do you even need to model the beam?
