Ansys Learning Forum Forums Discuss Simulation General Mechanical temperature contour not distributing correctly Reply To: temperature contour not distributing correctly
ashish.khemka
You can plot vectorial heat flux to see how the heat is being dissipated. Does this model has ekill commands implemented as well as you indicated in another post that it may not be working? If there is a bonded thermal contact with other portions of the model then the temperature transition should be continuous.
Regards Ashish Khemka
