Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Wrong flow direction in setup › Reply To: Wrong flow direction in setup
January 24, 2022 at 1:52 pm
Check which surface is set in the solver, the arrows denote the general direction of flow, so inlets enter the domain and outlets exit. To add, there's something odd in the Fluent plot, the grey should be uniform rather than shaded, so check how many walls there are.
