Ansys Learning Forum Forums Discuss Simulation Fluids UDF TO CHANGE BOUNDARY CONDITIONS Reply To: UDF TO CHANGE BOUNDARY CONDITIONS
It's probably possible via a scheme call, but that's not going to be as simple as you think. Execute commands allows this on a time basis in that you can set actions (TUI commands) to trigger every some seconds or degrees (linked to the cam shaft stuff for incylinder work).
