Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent – CAD Configuration Manager GUI Errors out on Startup Reply To: Fluent – CAD Configuration Manager GUI Errors out on Startup
satownsend
Hi Geo Certainly. I'll post the contents here between triple quotes. Thank you for the CAD Support document too, that helps a lot. We're running CentOS 8 here.
Log files is/top/level/path/redacted/ansys_inc/v212/CADConfigLogs/Latest/CADConfigurationMgr.log
MessageLogger.logFilePath is/top/level/path/redacted/ansys_inc/v212/CADConfigLogs/Latest/CADConfigurationMgr.log
ErrorLogger.errorFilePath is/top/level/path/redacted/ansys_inc/v212/CADConfigLogs/CADConfigurationMgr.err
System.TypeInitializationException: The type initializer for 'Ansys.UI.Toolkit.Application' threw an exception. ---> System.ArgumentNullException: Value cannot be null.
Parameter name: path1
at System.IO.Path.Combine (System.String path1, System.String path2, System.String path3) [0x00003] in <99e7772254e64ba29201f69df54e9889>:0
at Ansys.UI.Toolkit.QT.Application.SetPluginDirectory () [0x0000a] in <9f4c5c2f3917409682bcd57d61351152>:0
at Ansys.UI.Toolkit.QT.Application..ctor () [0x00006] in <9f4c5c2f3917409682bcd57d61351152>:0
at Ansys.UI.Toolkit.QT.UIFactory.newApplication () [0x00000] in <9f4c5c2f3917409682bcd57d61351152>:0
at Ansys.UI.Toolkit.UIFactory.newApplication () [0x0000c] in <3b1aa900de3e4d84a0c61b9093900a45>:0
at Ansys.UI.Toolkit.Application.InstantiateIApplication () [0x00000] in <3b1aa900de3e4d84a0c61b9093900a45>:0
at Ansys.UI.Toolkit.Application..cctor () [0x0000a] in <3b1aa900de3e4d84a0c61b9093900a45>:0
--- End of inner exception stack trace ---
at CADConfigUtilityGUI.CADUtilityApp.proxyMain (System.String[] args) [0x00113] in :0
_CADEnvironment not null
_cadConfig constructed
Exception caught in CADSetupTabPanel System.DllNotFoundException: Ans.QT.dll assembly: type: member:(null)
at (wrapper managed-to-native) Ansys.UI.Toolkit.QTC.TabControl.new_ans_qt_TabControl(intptr&,Ansys.UI.Toolkit.QTC.DisposableObject/ans_qt_DisposableObject_deleted)
at Ansys.UI.Toolkit.QT.TabControl..ctor () [0x00006] in <9f4c5c2f3917409682bcd57d61351152>:0
at Ansys.UI.Toolkit.QT.UIFactory.newTabControl () [0x00000] in <9f4c5c2f3917409682bcd57d61351152>:0
at Ansys.UI.Toolkit.UIFactory.newTabControl () [0x0000c] in <3b1aa900de3e4d84a0c61b9093900a45>:0
at Ansys.UI.Toolkit.TabControl..ctor () [0x00006] in <3b1aa900de3e4d84a0c61b9093900a45>:0
at Ansys.CadInt.CADConfigUtilityGUI.CADSetupTabPanel..ctor (CADConfigurationUtility.CadEnvironment cadEnvironment) [0x001bf] in :0 :
Done creating new CadEnvironment
Problem diplaying GUI System.TypeInitializationException: The type initializer for 'Ansys.UI.Toolkit.Application' threw an exception. ---> System.ArgumentNullException: Value cannot be null.
at Ansys.CadInt.CADConfigUtilityGUI.CADSetupTabPanel.Run () [0x00000] in :0
Run Complete
Alex
